Need Yanmar 3qm30h Fresh Water Pump
TUNG HWA FANTASIA 35 MKII Miami, FL
Hi,
I need part number 721390-43700 Fresh Water cooling pump.
They have been discontinued, does anyone know where I can
find one or is there an aftermarket version ?
Thanks,
Jules
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Hi,
Thanks,
Jules
is your pump rebuildable......
regards
woody
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
it might be, it's still on the engine, will know more tonight when I pull it.
if it is rebuild able look for the Flying Dutchman on the web...i had hime rebuild mine about a year ago...he is Oregon...and his name is Tony Cordelis or some thing like that ....he had the parts in stock to fix mine and was reasonable on priceing ...the pump is made by AISN......sorta like delco is to GM......hope this helps.......
regards
woody
Nov 6, 2006
10,253
Give these guys a shout.. they are your Yanmar distributor.. We recently rebuilt one using Yanmar parts and it was not expensive to do..
2801 Anvil Street North
33710 St. Petersburg (United States, Florida) T 727.522.9471
F 727.527.7013
I www.mastry.com
E sales@mastry.com
Claude,
The maintenance manual says I need a press to get it apart, is that so ? any
special tools needed to do this rebuild ?
Thanks,
Jules
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Claude,
Thanks,
Jules
i am not Claude but yes you do ....the guy in Oregon rebuilt mine for about $80.00 including shipping .....and all the parts are new.....give him a call and talk to him it seems to me to be the best solution ....the dang parts from Yanmar cost that much ...then you still have to take a chance on busting the housing when you press the old shaft out and the new shaft in ....
regards
woody
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I rebuilt mine using a large vice and a socket from my socket set to press out and in the rubber bushing. Rebuilt took about an hour and cost about 60 for a rebuild kit from my local yanmar distributor. There is no real "kit". The distributor just told me he used the parts diagram and gave all of the parts.
regards
woody
Woody,
I can't locate this person you speak of, there's a million listings for flying dutchman on the web and the only flying dutchman on this site is in maryland. do you have any more info ?
Thanks,
Jules
