Steve
I have two water tanks on my Catalina 30. One under the V berth and another under the starboard setee. The vent hoses had one way check valves that would not release the pressure on the tanks which caused them to fill very slowly and swell as well. I took the check-valves off the hoses which solved the filling problem except now water will run up and out the end of the vent hose into the boat. My waste holding tank on the port side is vented through a stancion. But not the others. I think I should vent them thru hull or deck has anyone encountered the same problem ....if so what is the answer?
