NEED TO REFINISH STAIRS ON A h33
99
hunter 33 marina del rey
I'm going to have to refinish the stair treads on my H33, 2005. I know that the balance of the interior is varnished, but the stair treads looked to have been oiled., I think that the stair treads are oiled teak. Any comments or how to advice?
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Are you sure that they are oiled, as oiled surfaces would be pretty darn slippery wet.
May 17, 2010
99
I've oiled other furniture
I've oiled and reoiled danish modern furniture in the past and once it's soaked in there is no surface oil.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Stair treads are bare teak and teak oil. You will want to do the treatment and then teak oil again. They are a PITA. I've been looking at cleaning them, varnish and installing something like treadmaster treads but haven't yet.
May 17, 2010
99
Thanks Scott,
After doing some searchs on this site, a number of guys/girls have been using something called Captain Johns as a cleaner first.
I looked into the idea of rubber treads also but the front of my stair treads are rounded.
I guess I'll try the Cap. John's than oil.
Dec 2, 1999
15,184
You can always varnish or use other finish and a little sand to make them non-skid. There is also the 3m non-skid tape too.
Sep 20, 2006
2,955
Thanks Scott,
Mine's a 2005 as well. I never thought of the curved front, I was just brainstorming and didn't measure yet.
Treadmaster does have larger sheets that could be cut? Treadmaster Flooring again I'm just brainstorming.
We have a dog and are constantly on shore and back onto the boat. The stairs take a constant beating as far as dirt etc.
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
I think you can get some non-slip "granule" stuff to mix into your varnish.
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
Paul,
I refinsihed my companionway ladder 10 years ago as a Winter project and it is still in perfect condition. Before sanding, clean the surface with any marine teak cleaner, allow to throughly dry, and sand until the surface is clean. I used Epifanes and built four sub coats with the gloss and finsihed with two coats of the matte finish. I then applied Treadmaster self adhesive pads (ivory) and positioned them close to the outward edge of the step to prevent slipping. It is functional and looks like a fine piece of furniture. A great Winter project. Good luck, Ron
Eric M
Sep 30, 2008
159
Island Packet 35 Jacksonville
We wraped the stair treads with a piece of burber carpet from a big box store and simply used a staple gun to secure the carpet to the bottom side of each tread. It's softer on the feet and our lab is much happier with having something to get a grip going up and down. 3 years later and they still look good.
We use Scott's Liquid Gold on all of our interior teak. It is inexpensive, and it lasts a full year even here in the FL heat.
--Eric
