Need rubber caps for
31
Oday 25 Cooperstown, NY
My swim ladder.
The 2 legs that stick out from the frame of the ladder are missing the plastic/ rubber caps that actually make contact with the stern.
SUDDENLY they are BOTH missing. Which leads me to believe something unsavory has happened to them and it seems odd that they would both be missing when they were both there last week. :cussing:
Anyway they are 1" caps. Where do I get replacements. I've been searching and no joy.
Jun 1, 2004
95
Hunter 27 Cave Run Lake, Morehead,KY
Crutch Tips
I found rubber crutch tips at my local Lowe's store. They come in a variety of diameters. They worked better than the originals, and they are cheap.
zeehag
Mar 26, 2009
3,198
My swim ladder.
2 things you can use successfully for the ladder ends--there is , in walmart, better known as wally world, tips --i found them in the tool section next to the vacuum cleaners in slidell, la......also can use tennis balls....both are inexpensive...
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
go to your local ace hardware or drug store and ask for crutch tips...and when you get them put ss flat washers in them so the tubing of your ladder wont cut the inside rubber when under pressure.....
regards
woody
Ross
Jun 15, 2004
14,693
The hardware stores have them, the drug stores have them, the super markets have them, walmart has them.
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
Lowe's Has them as well
Look in hardware. They don't call them crutch tips (probably chair ends). As I recall I got 4 for under $2.00.
Mar 13, 2009
158
irwin 37 (73-74) grand harbor marina
Re: Lowe's Has them as well
TENNIS BALLS!.. go zee! yeah walmart, walgreens, target, sears, grocery store.
wait does the bottom of the ladder have a crook in it? you might want to look for tennis elbo's sorry bad day! jimbob
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I got about two seasons out of the Ace Hardware ones FYI.
Catalina 320 Dana Point
Did you notice in Steve's google link that Worst Marine was selling 4 chair tips for only $12.49? They must be far superior to the identical ones Ace Hardware sells for $1.29.
Jun 22, 2010
31
Imagine my surprise.....lol
I used the crutch tips I had hanging around from some old injury and put the washers in them as suggested.......
They work great. Tight fit and problem solved.
Thanks again.
Oct 29, 2005
2,366
Ed, next time you can try the Pet bottle cap. If its not tight, just run a short length of self vulcanising tape around the 1" pipe and screw the cap in. That's what I use for my 1" stanchion top when I lost the stanchion end cap.
