Need advice rigging spinnaker halyard
7
Hunter 30 Rescue
Trying to figure out the best way of running the spinnaker halyard out of the sheave box and forward of the forestay. I do not have a roller furler, just the standing rigging. There is a large padeye pointing forward at the mast head. It almost seems like I could lead the halyard out of the sheave and thru the eye then down to the deck. It looks like attaching a block to the padeye will cause the halyard to rub across the top of the masthead toggle attaching the forestay. I have the 40'6" Kenyon mast and it has two forward and two aft internal sheave blocks. Any ideas on what will work here?
5,802
My H37C has the Kenyon mast with four sheaves and the forward facing bale. I put a three inch block on that bale. I ran a new halyard over the forward port sheave and through that new block for the spinnaker, actually a simple drifter.
Mar 11, 2009
207
Hunter 40 Saint John
We did the same
:)Although we had to install a new loop for the mast, then we simply took a halyard and ran ir through a 2 inch swivel pulley and voila, we had a new spinnaker halyard
Jan 22, 2003
744
Hunter 25_73-83 Burlington NJ
Preference for external spinnaker halyard.
Although I have double halyards for both main and jib, they're used for those. The spinnaker halyard is external (same as in Cherubini 44s). I don't see why it has to be any other way.
I have the spinnaker halyard and pole lift running down the front of the mast through those nice Ronstan bullseyes with the stainless-steel inserts. With the pole lift fixed rather high up it can serve as an inner-staysail halyard and in the event I lose one I have THREE other usable headsail halyards to use in some combination.
I do not care for sacrificing a potential jib halyard merely to have the spinnaker halyard internal. And this is especially because of, and not in spite of, having a roller-furling headsail. Too often the roller-furling jib's halyard gets bent over a sheave up there and never moves again, imposing wear and fatigue. I believe in being able to reassign halyards frequently to preserve them, inspect them and avoid catastrophes.
Then again you may not fly a 'chute' that often and will end up using the spinnaker halyard as a back-up or frequent secondary halyard anyway, which is fine.
Apr 5, 2009
7
Hunter 30 Rescue
Well, went with the external option. Ran the spinnaker halyard down to a second block at the base of the mast then back to the cockpit. Didn't have a lot of wind but it was good to see where to go next with a more permanent setup :dance:
Thanks for the advice all!
207
I am going to do the same and put an external line on as well, that way, we can raise and lower the spinnaker from up front instead of bothering the crew trimming other sails
