Ok, last thing...where the mast mounts to the deck (see pics) the steel plate doesn't appear to be fully secured. Not sure why this is??? Fiberglass appears safe and sound. Should be easy to either tighten down or re-drill holes and fix this right?Clark said:Billy, you can sail w/ main alone but it won't be very balanced and you'll lose a good third of your performance. A decent used jib is ~ 200. Check at:
http://www.mastheadsailinggear.com/UsedSailSearch.aspx
