need a pearson ariel or p26 mast 30'3"
1
2 Ariel Lake Martin
Looking for a mast for a pearson ariel. Its 30'3" long, about 3.5" X 6.0" diameter. A p26 mast probably would work. I'm located in central Alabama and would be able to drive a reasonable distance to pick it up.
Tommy Palmer
palmertommy1@hotmail.com
Pearson 26W Marblehead
pearson ariel mast
I have a pearson 26W The Mast height measured from the waterline is a little
over 35' which means its going to be taller than your pearson ariel mast. If you can find one you can probably shorten it. Any mast longer than the height your looking for should do. A catalina 27 mast would most likely do the job
They built lots of them. D&R marine in Assonet MA bought up all the old pearson parts. Metal Mast marine in RI was the original mast maker. But its
probably going to cost more to ship the mast than its worth. Your best bet
is to try to find a used mast from a wrecked boat around the same size or
E Bay , Craigs list etc on the Net. One more thing what ever mast you wind up with make sure to get the step with it. Your step might not fit a mast from
a different boat. Good luck
