LED Nav Lights Test
About a year ago I participated in a Nav light test run by Practical Boat Owner magazine here in the UK. Practical Boat Owner is the largest selling sailing mag we have.
I made a fixture for the lights which could be rotated 360° and also tilted by 5° up and down and by 25° up and down. We found a local bay on the Solent and, using GPS, we set up a team of observers EXACTLY 2 miles away. The nav lights were run from a car which was directly on the sea wall and the shoreline was completely uninhabited so was completely dark.
We ran each light in turn and used an old, slightly crazed, conventional incandescent vertical filament 25 watt nav light as a comparison.
Our findings were that only the custom made LED lights were as bright as or brighter than the 'normal' incandescent one. i.e. those with the LEDs built into a custom fitting.
The LED clusters were not.
Also, apart from reliability issues mentioned elsewhere, the LED clusters still suffer from the major source of unreliability in that they use the conventional bulbholder. In many instances the contacts gather a little corrosion and this insulates the bulb from the supply. Perhaps worse with the LEDs because of the smaller current and less heat.
In general even the brightest of the lights was eminently missable at two miles unless one was concentrating and looking in exactly the right direction. How they would have looked through the glass on a ship's bridge is anyone's guess - and they need to be seen at 3 miles for vessels over 12 metres.
For interest we also tried a 500,000 candlepower torch shone directly at the viewing team - UNMISSABLE even if not looking towards the light.
For my interest only I got a rotating yellow light from a motorway service vehicle and ran that too. The idea being to only turn it on when a ship was coming dangerously close and apparently had not seen us. This light was 48 watts with a rotating reflector. This is totally illegal and specifically banned in the COLREGS but some of our fishermen are stealing? them from motorways and fitting them on their boats.
My verdict on the rotating amber motorway light - THE BEST OF ALL for drawing the attention of an inattentive watchkeeper. Of course it could be any colour and the rotating beam is unlikely to be confused with any other normally flashing lights because of its 'lighthouse' like signature.
Remember also that our tests were done over two moonless nights with no background illumination and the weather was PERFECTLY CLEAR.
Our findings were that the only way to be sure of being safe is to take the initiative and get the hell out of the way of anything big and looking as if it is on a collision course is coming your way!
