My holding tank is clogged
28
Catalina 36 Bristol, RI
Peggy, My holding tank appears to be clogged at the outlet. Can't empty it by pump-out or macerator. I have a snake, but there is an elbow at the outlet that may prevent it from reaching the clog. I would hate to have to take the hose off the outlet end. That would be a true mess. I can get at the outlet through the hose from the macerator end. Any suggestions? Les Murray s/v Ceilidh '86 C-36 #560
May 18, 2004
385
Catalina 320 perry lake
vent
are you sure that the vent is not clogged? if it is, the pumpout just pulls a vacuum on the tank and not much will come out.
Dec 2, 1997
9,011
- - LIttle Rock
Bill is right...
Unless someone has flushed something they shouldn't have, it's far more likely that your tank vent is clogged than it is that there's a clog in the tank discharge. This time of year especially, blocked tank vents are a very common problem because insects like to build nests in the thru-hull...and because people don't flush 'em out in the fall. The two most likely places for a blockage in the vent are the thru-hull and the connection on the tank. Check both and scrape out with a screwdriver blade or similar instrument. Don't use the toilet again or attempt to pumpout again until you're sure the vent is clear. And in the future, check your vent thru-hulls regularly and backflush 'em each time you pump out and/or wash the boat.
