Don Bodemann
Lock the swing keel?
If I picture my typical swing keel like a C-22, and the boat gets knocked down. Now the mast is horizontal as well as the keel. Only after the boat turtles will there be any gravity force pulling the keel down into the boat. These keels are not mounted in ball bearings but rather a large, crude, pin. I would guess the mast would have to be pointing down into the water approx 20 degrees or more before the keel would start to retract...and at this poin t you're in deep **+^! anyway. We could ask Mr. Butler why there is no lock on the C-25? From my discussions on the C-22 e-mail list, there are as many lockers as non lockers. Many times sailors have tryed to retract the keel forgeting they had locked it. Again, this can and will cause a nasty leak. there are many C-22s with the lock removed and glassed over for this very reason. So should you lock? After all, why did they put that thing on the boat if you shouldn't use it.The choice is yours!
