I was starting to see spider cracks around the mast step so I cut away the fiberglass skin and as expected I found wet and rotten wood underneath. I have it 95% cleaned up to re-glass it. It was 1/2" plywood under the skin with no filler that I could see. I'm familiar with different techniques but my question is which one to use?
I figured I'd pour some thickened epoxy into the cavity, then plywood, perhaps a layer of 1708 and then gelcoat? Or should I skip the 1708 and use all thickened epoxy and gelcoat?
I'm familar with the execution but I'm not sure which materials would be appropriate for this application
