Some Answers...
Hey shfrantz,I bought my fist boat, a '77 Catalina 30 about 4 years ago & I know what you're going through. Here are some answers to your questions:1. Water in the deck core. This is a major problem if the core is soaked as your description suggests. It's possible (though unlikely) that the water is between layers of fiberglass, but even that is a red flag. Here's why: The deck has a wood core that is sandwiched between two layers of fiberglass, one is the deck on the outside of the boat, and the other is the headliner inside. Boat builders do this because it creates a relatively light but very strong deck. The problems happen when water finds its way into the wood core. This usually happens where a fitting is drilled into the deck, like a stanchion or perhaps (in your case) the mainsheet traveler. At any rate, when enough water seeps into the deck core the wood will eventually rot & ruin the structural integrity of the deck. It's a messy expensive job to fix & it's a good reason to walk away from the boat if you think that's happened. If you're not sure, have a qualified surveyor take a look. It will be $$ well spent.3. Wiring: My lights have needed work over the years, too. It's a fact of boating especially if you're in salt water. The good news is that running new wires isn't too difficult for the running lights, and oftentimes all you need is a new bulb. The only wires that are a real pain to run are those that go up the mast. Does your anchor light work?? If so, this isn't cause for concern.3. Sticky wheel: It sounds like you either need to lube your steering cables or you may have a bad pulley. It may cost you more than you'd expect, but it shouldn't be a reason to walk away. You mention that this happens when the boat is "under sail". How does the wheel turn when under power? How does it turn when at the dock? Another possibility is that the boat has a worn rudder post. Again, this isn't too big a deal to fix. As a side note, it amazes me how expensive some of those parts from Edson can cost (I bought a new quadrant in '01 and it was over $200 if I remember right). On the flip side, I'm glad they're there because if I had to hire a machine shop to measure & fabricate one, it would have been a lot more. Oh well.4. Impeller replacement: The boat does not need to be hauled to replace the impeller. All fittings that go through the hull (appropriately called thru-hull fittings) will have a sea cock valve that will allow you to close the opening in the hull for service & in case you have a broken or leaky hose below the waterline. Replacing an impeller is an easy job. While we're on the subject, make sure you check that all sea cocks open & close. Sometimes they can break and/or sieze over time.Overall, I'm guessing 2 things about your questions. First, it seems like you're new to sailing which is great! Just make sure you don't make the mistake of not getting the right support as you buy a boat. Hire a surveyor. After you've bought the boat take a coast guard class or one by the US Power Squadron. Perhaps the seller can "show you the ropes" (literally!). Many people try to figure it all out on their own and it can cost them BIG TIME either in a boat that hit the rocks, someone getting hurt or you might just look like an idiot.The second thing I'm guessing is that this boat has either been sitting unused for some time or at least hasn't had any maintenance for some time. That can be both good & bad. I wanted a fixer upper so I purposely sought out a boat that was neglected & I found one. I'm handy and I was happy to do the work myself & save a few bucks. This may not describe you, though, so figure out how much reapir work you want to sign up for & pick a boat with the appropriate price that meets your needs.That soggy deck is a major concern for me. If you absolutely LOVE the boat, then get a survey. If you're not in love with the boat, I'd walk. There are literally THOUSANDS of C-30's out there & you're better off being patient and waiting until you find the right boat. I'd go to www.yachtworld.com to see some C-30's for sale, even if you want to compare your boat to other in the marketplace.Good luck & let us know if you have any more questions!!!Allen Schweitzers/v FalstaffC-30 Hull#632
