"Multi Ring Deck Organizer"
Dec 7, 2018
242
C&C 27 Mk V Vancouver
Write up implies these can replace regular organizers w/sheaves...anyone doing this?
I'm using D-Race - be about a 40 deg bend....
I have not used those but I have used the low friction rings as a subsitute for a block. So far no complaints. If you try it, please post pics of the installation.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
Lead rings are becoming quite common and this deck organizer seems to be very similar. Might even be better than an organizer with sheaves if the entry angle is not parallel to the deck. I just picked up one of these to try for my spinnaker tack line.
You asked about the deck organizer and all I can say is that the ring seems to work well as far as friction goes. This is not a great pic. I took this as I was testing out an idea but I don't have a pic of the final setup. I ran this ring on a line through my deck block and I run my jib sheet through the ring. One of the things I didn't like about the H26 set up is the lack of jib cars. My jib block is set rather inboard which is great when working to windward but on all other points of sail, the jib pinches the slot. When the wind is beam-to or abaft, I use the line that runs through the block to let out the ring... this lets me ease out the clew and open the slot. I call it a reverse Barber Hauler but I'm not sure if that is a good name or not. My reverse barber hauler sort of works but it adds a lot of clutter to the cockpit (two extra lines). When working to windward, I pull it all the way in and my sheet is nearly in the same place as it was in the original block.
Likes: DArcy
AaronD
Aug 10, 2014
762
Catalina 22 9874 Newberg, OR / Olympia, WA
Huh?
Leading back to rope clutches. I thinking for halyards, outhaul, vang - not stripping cover from line either.
I think @DArcy is thinking of a situation where either 1) The mast turning block is significantly above deck level; or 2) The deck is curved substantially. In either case (or the combination of the two), the incoming line from the mast would enter the organizer at an angle (not perfectly straight into the sheave). If so, there might be a tendency for the line to ride up out of the sheave and jam alongside it against the frame of the organizer.
Sheaveless organizers wouldn't have that possibility.
I had it happen once, and it was a real pain to clear. And could have been a trip-killer if I'd ended up cutting and accidentally sky-ing the halyard. In my case, it was a combination of 1) Stripped halyards, with skinny 1/8" Amsteel passing through the organizer; and 2) Organizers (intentionally) slightly oversized for my boat (38mm sheaves), leaving a bit more gap on the side than a smaller organizer would. When I replaced the halyards, I left a longer cover, so now they're covered through the turning blocks and it won't happen again.
Joe
Jun 1, 2004
8,309
You can just call it a Barber Hauler..... it doesn't make any difference which way it pulls. In-haul or out-haul. On my Nacra, (beach cat) the barber hauler is rigged to move the lead position outboard. On my Catalina 27, I use the genoa track.... and rig a barber hauler to move the lead position inboard. Same purpose, different direction.
dLj
Mar 23, 2017
5,049
I find it interesting the wax and wane of systems and methods. I used to turn these parts out of teak, iroko, lignum vitea or other woods years ago...
dj
