Write up implies these can replace regular organizers w/sheaves...anyone doing this?
I'm using D-Race - be about a 40 deg bend....
Huh?if the entry angle is not parallel to the deck.
I think @DArcy is thinking of a situation where either 1) The mast turning block is significantly above deck level; or 2) The deck is curved substantially. In either case (or the combination of the two), the incoming line from the mast would enter the organizer at an angle (not perfectly straight into the sheave). If so, there might be a tendency for the line to ride up out of the sheave and jam alongside it against the frame of the organizer.Huh?
Leading back to rope clutches. I thinking for halyards, outhaul, vang - not stripping cover from line either.
You can just call it a Barber Hauler..... it doesn't make any difference which way it pulls. In-haul or out-haul. On my Nacra, (beach cat) the barber hauler is rigged to move the lead position outboard. On my Catalina 27, I use the genoa track.... and rig a barber hauler to move the lead position inboard. Same purpose, different direction.. I call it a reverse Barber Hauler but I'm not sure if that is a good name or not.
I find it interesting the wax and wane of systems and methods. I used to turn these parts out of teak, iroko, lignum vitea or other woods years ago...Lead rings are becoming quite common and this deck organizer seems to be very similar. Might even be better than an organizer with sheaves if the entry angle is not parallel to the deck. I just picked up one of these to try for my spinnaker tack line.
