Moving exhaust below waterline
Sep 24, 2018
4,779
Catalina 30 MKIII Chicago
On the Catalina 30 MKIII, the exhaust swirls back into the cockpit and cabin. It stinks and leaves a mess all over the transom as well. The through hull is above the waterline with occasional dips below. Would moving the through hull below the waterline help? What, if any, modifications would be needed to prevent water intrusion?
Have you asked the fish how they feel about diesel exhaust in their home? ;)
The exhaust hose has to rise well above the waterline at any angle of heel. The length of the hose is also an issue. When the engine is shut down any water in the exhaust line before the high loop will drain back into the muffler and potentially into the exhaust elbow if the run is long and the exhaust line isn't cleared.
dLj
Mar 23, 2017
5,222
An old expression comes to mind: "The enemy of good enough is better."
dj
Sep 25, 2008
7,744
Alden 50 Sarasota, Florida
Keeping the exhaust thruhull above the WL ensures that siphoning backwards when shut down cant happen. The gravity loop ( elbow ) won’t prevent that in all cases.
Sep 30, 2016
449
Island Packet IP 44 Ventura, CA
Exhaust exits above water line: gas swirls with the wind.
Exhaust exit 6" below water line: Gas bubbles up 6" and swirls with the wind.
Dont motor downwind, or sail more. My wife hates diesel exhaust as well. Not much you can do about it.
