Yes, but why pay MORE money for a radar reflector that is CLEARLY LESS EFFECTIVE??? BTW, I was basing my statement on efficacy on both tests and RW experience using radar.
I'm basing it on boats I've SEEN. When I see them come out of the fog one of the first things I do is look to see if they have a reflector. If I never saw a boat I don't know if they had one or not cause I never saw it. The bottom line is that nearly every boat I have seen pop out of the fog within sight that I have also picked up on radar ahead of time has had a reflector, any reflector. I have often never picked up boats on radar that simply pop out of the fog, "honey I'm home"
, and guess what, more often than not they don't have any reflector at all..
I have two types on board a Davis and a Mobri. The Mobri is always up there which provides a greater safety factor than forgetting to hoist my Davis. In thick fog I run both. I have spotted tons of boats boats with Mobri reflectors but do agree that the Davis shows up as a larger target.
Here is an actual photo of two boats, one with a radar reflector, and one without. I will have to check later today to see what reflector the Morris uses, can't remember. The bottom line is if any reflector is being used it is better than none at all. I do see more people actually USING Mobri's than I do other styles, perhaps because they are easy to leave up. More often than not when sailing on OPB's, in fog, the reflector is left as an after thought in the lazarette. No matter how good it is it won't do much good if it is not hoisted..
