Mounting a Radar Reflector
Rick D
Jun 14, 2008
7,204
Above The Spreader
Mine is mounted just above the first spreader with monel wire. It has been there for at least ten years, probably 15.
Feb 10, 2004
4,234
Hunter 40.5 Warwick, RI
I have the larger size and I have attached it just above my second spreaders using small screw-type hose clamps. I would not use wire ties due to the UV degradation of them. I know that there are some black ties that are resistant to UV, but I felt that security of the metal clamps was better.
FWIW, I had water intrusion in my reflector after a year and I drilled a 3/16" hole in the bottom cap to allow any water to drain. I don't take it down over the winter and I didn't want a freezing issue. Maybe my reflector was not sealed as well as it should have been, so your mileage may vary.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Just be aware that the Plastimo radar reflector isn't very good compared to some of the others in terms of showing up on radar. Also, the reflector really needs to be mounted as close to vertical as possible for best results. If you're going to use cable ties to mount it, use the black ones, as IIRC, they have the best UV resistance. Personally, I think using a line and lashing the line to the shroud would be better than using a cable tie.
Rick D
Jun 14, 2008
7,204
"Just be aware that the Plastimo radar reflector isn't very good compared to some of the others in terms of showing up on radar".
Based upon actual experience, I don't disagree. But, it is still a meaningful improvement. And, I consider it like a life preserver: the very best one is the one you wear most. This offers minimal windage and weight and you mount it and forget it.
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
Dan, I read a report on it and agree their performance is poor. Unfortunately I couldn't afford much more. I bought a bunch of last minute items for the boat... Jack lines, teather, safety harness, radar reflector and a grill mount.:dance:
They perform better vertically mounted yet none of the rigging is actually vertical. There is some angle to each stay. I ended up mounting it like Stu did in his picture. Like Rick D said, it better than not having one at all.
http://www.ybw.com/pbo/pdfs/radar_reflectors.pdf
Not to get off topic but boy has the weather been crappy so far this season :cry:. My wife and I are planning a week in Nantucket the end of this month. The extended forecast show rain rain rain!:eek: Never been to Nantucket, any words of wisdom for the trip?
Bob
Oct 22, 2008
3,502
Bob—
The Davis Echomaster Deluxe is a far better unit, and less expensive too boot.
I use it on a halyard that goes to the upper spreader on my rig, and there are two blocks mounted to the underside of the spreader, which allows the radar reflector to hang without chafing the halyard. I leave it up 95% of the time—taking it down for bad storms when I'm not sailing.
The trip to Nantucket is a good one.. but keep an eye on the currents, especially when going through Woods Hole, and watch out for the fog and ferries.
Mar 20, 2004
1,753
Don't use the cable ties unless it's really temporary. My dealer installed mine with cable ties (I didn't know) and they came off-could have hit someone or something....Lash or clamp it in place properly. The larger size (Rich's setup) is much better than the littleones-If you can, return it and get the davis-we've done tests, and they are much more effective.
Oct 22, 2008
3,502
Considering that the 4" version did poorly, I'd hate to think how well the 2" version does. IMHO, getting the 2" plastimo/mobri radar reflector is a poor idea, since it really does nothing to increase your radar profile significantly—and can lead to a false sense of security. The Davis Echomaster Deluxe is less expensive, and has a much greater radar return generally.
Feb 6, 1998
11,759
Tests schmests..... In my own real world experience I would honestly say that I have rarely not seen a boat with ANY reflector yet missed lots without reflectors. Sure, there is a "range" of performance but even the worst performing radar reflector, when properly used, I find works better than none at all. It's not like we don't get to use our radars much up here in Maine either...:D:D
Nov 22, 2008
3,562
Endeavour 32 Portland, Maine
I would honestly say that I have never not seen a boat with ANY reflector...
Now, how are you sure that boat you didn't see didn't have a radar reflector?:)
I'm curious about the rain catcher vs up and down orientation of the standard round Davis type of reflector. This seems like a good subject for one of your photo essays. I would be glad to give you some help with it sometime.
Oct 22, 2008
3,502
Yes, but why pay MORE money for a radar reflector that is CLEARLY LESS EFFECTIVE??? BTW, I was basing my statement on efficacy on both tests and RW experience using radar. :)
Tests schmests..... In my own real world experience I would honestly say that I have never not seen a boat with ANY reflector and missed LOTS without reflectors. Sure there is a "range" of performance but even the worst performing radar reflector, when properly used, I find works MUCH, MUCH better than none at all. It's not like we don't get to use our radrs much up here in Maine eitehr...:D:D
Feb 6, 1998
11,759
I'm basing it on boats I've SEEN. When I see them come out of the fog one of the first things I do is look to see if they have a reflector. If I never saw a boat I don't know if they had one or not cause I never saw it. The bottom line is that nearly every boat I have seen pop out of the fog within sight that I have also picked up on radar ahead of time has had a reflector, any reflector. I have often never picked up boats on radar that simply pop out of the fog, "honey I'm home";), and guess what, more often than not they don't have any reflector at all..
I have two types on board a Davis and a Mobri. The Mobri is always up there which provides a greater safety factor than forgetting to hoist my Davis. In thick fog I run both. I have spotted tons of boats boats with Mobri reflectors but do agree that the Davis shows up as a larger target.
Here is an actual photo of two boats, one with a radar reflector, and one without. I will have to check later today to see what reflector the Morris uses, can't remember. The bottom line is if any reflector is being used it is better than none at all. I do see more people actually USING Mobri's than I do other styles, perhaps because they are easy to leave up. More often than not when sailing on OPB's, in fog, the reflector is left as an after thought in the lazarette. No matter how good it is it won't do much good if it is not hoisted..
Oct 22, 2008
3,502
I leave my Davis Echomaster up most of the time, except if we have a storm coming in. It is hoisted on a halyard that was setup just for the radar reflector, which has two blocks mounted about a foot apart on the bottom of the top spreader, to prevent the refelctor from chafing the halyard.
Mar 20, 2004
1,753
like maine sail, we did some informal tests in our rare maine fog during our annual Maine Hunter Sailing Association flotillas. I agree any reflector is better than nothing, but.. Escape showed up better with the Davis than with 2 of the small Mobris, and much better with the medium size tri -lens. Once the mobris fell off, we installed the tri-lens on the mast-I'll report back after we do some testing. As maine sail said, anything up is better than a reflector in a locker
Dec 2, 2003
1,637
Radar Reflector Performance
Now that we have the attention of the experts I thought it might be appropriate to toss this into the ring.
After the assumed running down of a small yacht on a clear night by a ship - and the loss of three lives, the UK govt department dealing with such matters did an analysis of the probability of a yacht with a reflector being seen by a ship's X band radar.
The weather conditions were a brisk breeze but nothing approaching heavy weather.
At no time did the ship's radar 'see' the yacht nor was there any record on the ship's voyage data recorder. The lookout did not see the yacht's nav lights until 300 yards range and the yacht then passed close down the ship's side. It was not established whether a collision occurred. The ship did not stop not did it call the Coastguard. The captain is now in jail.
The yacht was understood to be wearing a Davis reflector in the double catch rain position and by common agreement the Davis is amongst the best reflectors for yachts.
The attached graph shows that regardless of reflector area there are distances where the yacht would have zero probability of appearing on the radar screen. Most notably at 2 miles and 4 miles (6 minutes apart at 20 knots). So if this was when the OOW looked at the screen the guys were as good as dead already.
3,562
Wow. Very sobering. In my very limited experience of watching targets approach on my new radar, I seem to have observed the same sort of nulls. Some targets appear far out, disappear, and then reappear closer in.
I wonder what causes this and if it is specific to radar reflectors. I'm seeing a case developing here that two radar reflectors in different positions or perhaps two different kinds of reflector could be far more effective than one of any type.
