fastscot, sorry I missed your post. I have been rather busy.
I poured it all at once.I used West System slow hardener and worked in a cool (55 degree)room. The epoxy was thickened with West System #404 high Density filler to a consistency of between mayo and peanut butter. My wedge was filled with wood blocks, so to help with strength, I got 6, 3" stainless screws (#10) with 3/4" fender washers and screwed 3 into each side about an inch deep. They were alternated so they sort of interlaced. To hold it all together, I made frame out of some scrap 3/4" plywood. It was L shaped, and large enough to have room around the sides and bottom of the block. The short side of the L was held square with scraps screwed to the sides. I then marked which holes on the motor mount lined up with the existing holes on the split mounting block, the put he motor mount against the top of the frame and marked where to drill 5/16 holes, drilled holes in the frame and bolted the two halves to the frame, with a couple layers of wax paper so the epoxy wouldn't stick to the plywood. Then the frame should be leveled so the back side of the mounting block, which is now up, is level. If I remember right I also cheated on the amount of hardener I put in to slow the kicking process. I scooped the mixture in with a putty knife and made sure there was no air bubbles, and smoothed it and let it cure. To get a nice tight fit on the transom, I used carbon paper to mark high spots and took them down with a belt sander. I hope this makes some sense, if not, let me know.
