More Sail Equals less Heel?
geehaw
May 15, 2010
231
O-day 25 shoal keel Valdez
Well Been able to get some long sails in this year. ! week around Memorial day, 4 days Independence Day and just got done with 4 more. Well had light winds so decided to get out the 130 (I think)Genoa. Having been a little apprehensive before this because of my inexperience. It was the best thing I have ever done. The boat handles better, is less cranky. Sailed a broad reach for 5 hours on the 4th 20 knot winds The next day returned on a close haul winds picked up again to 20+ Had full main and the genoa. Heeling stayed mostly at 15 degrees speed was consistently above 6 knots.Gps said 7.1 max speed. So my question comes to if I have regular jib in same winds I have a hard time keeping it under 25 degrees of heels and speeds are in the 3 knot range extreme lee helm. But with the 130 heel was consistent and gust it would heel just a little more and turn into the wind and settle down and keep on it's course all under auto helm. Why?
Jan 22, 1999
62
Hunter 35 PENSACOLA, FL
Mast Rake Setting.
Who ever set up the length of your fore stay did so for a 130 Genoa.
When you flew your 110 the mast rake was not set for that size sail.
There is a different mast rake setting (fore stay length) for each one of your head sails.
That with the smaller 110 and the weather helm and slow water speed the rudder was causing a great deal of drag.
When you went to the 130 headsail the rudder was very happy, you had a higher water speed because of less rudder drag (IE. weather helm).
Setting mast rake is not hard but it is head sail specific.
There is a lot of information in in the archives on this subject.:)
If needed ask some more question and the Hunter owners will be glad to help.
Broad Reach
geehaw
May 15, 2010
231
Re: Mast Rake Setting.
I have a 100 jib and it's an Oday!
Joe
Jun 1, 2004
8,323
Broad Reach
Are you serious? You mean if I'm racing and change from the #1 genoa, to the #2 Lapper or the #3 blade, I have to go forward and alter the forestay length so I can change the mast rake for each sail? LOL
Adjusting the mast rake is NOT headsail specific.... whoever told you that?
Geez.
Oct 2, 2006
1,517
Jboat J24 commack
Re: More Sail Equals Lwss Heal?
Kind of hard to believe a 25 shoal keel boat could carry a 130 and full mainsail in 20 knots and only heel to 15 degrees
The whole lee helm thing with the 100% makes no sense at all as if your overpowered and setup correctly you should always have weather helm and might get some lee helm in light air
I'm no expert but ...
Maybe your smaller jib is blown? With out the "slot effect" you main does not give you the performance it should and so you have two sails under performing = 3 kph.
I have three head sails, a 50%, a 75% and a 110%, and I can reef my main by rolling it on the mast. I have found that if I play with the relative proportions of my two sails and get them balanced (and I'm not sure of the physics of this, I just go with my gut) the boat does tremendously better and I can feel safe and move well in strong winds.
Next time you are using your smaller headsail, try reefing the main and see if you can get them "balanced".
I have also observed that in higher wind, you need to keep up your forward speed through the water if you want to feel in control. So maybe you are seeing that effect. You boat is moving faster with the genoa so it behaves better. (?)
It is also true that a flatter boat moves faster. Is it possible that you are hauling in harder on the sheets when you had the smaller headsail up and maybe you had the main and genoa eased a bit when you were running under the genoa?
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
unless his old jib is so blown out that it has a belly like a spinnaker... I bought new sails this year, upgraded my genoa from a 110 to a 135, and I have alot less heel even in higher winds...
Apr 22, 2009
342
Pearson P-31 Quantico
I think this can be explained by looking at air plane wings. A C-130 has a large thick wing. At low speeds it has a lot of lift but at higher sppeds, it loses its efficiancy and causes excessive drag. So much drag that regardless of the power you apply, you can't go super-sonic.
Take a 767, the wing is larger in nearly every aspect, but it is shaped to be "super critical." Thus, even at higher speeds nearing mach, the wing remains efficient (and saves fuel).
If you want to do the work, put some markers on both sails and take comparative pictures. You will probably see a dramatic shape difference.
Jan 22, 1999
62
Mast Rake Basics
To Joe and his Catalina in the California,
I know from experience (race/sail a Hunter Legend 35) that head sails are rake specific. If you don't believe it try it. ;)
Try sailing a 155 with a 110 rake set up..
What type of sail do you race with ??
What is your mast rake ??
What mast rake does Catalina recommend ??
I know what Hunter recommends and why.
As to the racer who changes sails during a race: if you look closely on most race boats the fore stay turnbuckle is exposed.
Broad Reach
Oct 2, 2006
1,517
Jboat J24 commack
Around here it is against the rules to adjust the rig during a race other than the backstay
On everything i sail from a J24 on up the headstay is set at length X and not adjusted as i would love to see somebody on the bow turning a turnbuckle when the wind picks up and your changing down to a # 3
Dec 17, 2008
35
Morgan 30 Classic Long Island
Sounds like you flew the Whomper on the Oday 25.
Actually, I see the Oday 25 having a shorter boom then an older boat like mine, thus the foward sail does alot more for the boat then mine. Maybe that is what you are experiencing. That the boat is designed with less main and more foward sail to get it going more effeciently.
Any thoughts?
Joe
Jun 1, 2004
8,323
Do you have any other source of reference for this concept?
I do that all the time.... no problem.. when employing normal adjustments such as jib lead position, halyard tension and headstay tension (backstay).
Sails...... not sail... I have a set of upwind sails that can be interchanged for various conditions during a race. A symentrical spinnaker with pole, an A sail for reaching and a tall staysail. I never fool with the headstay turnbuckle while sailing.(nor do I know anyone that does)
3 or 4 inches
They recommend mast rake be set during the mast tuning phase when setting up the boat. Normally around 3-6 inches depending on the amount of weather helm you prefer.
For my Catalina 27? Perhaps a quote from the Hunter owner manual would be enlightening.
Broad Reach
That's interesting, have you ever seen a crew adjusting it during a race? BTW almost all boats have the headstay turnbuckle exposed... so it can be adjusted. However, on many roller furling systems the turnbuckle is not easily accessed..... how do you explain that?... do all hunter's with roller furling have their turnbuckles exposed? And do all Hunter owners adjust their turnbuckles whenever they change sail sizes? Such as when reefing. Is this recommended by Hunter?
Pre setting the mast rake is for setting the vessel's overall weather helm. The headsail is somewhat irrelevent in this process because the weather helm can be tweaked with other, more convenient controls.
If you reef your roller furling headsail do you run to the bow to adjust the headstay tension, then go back to make another adjustment when you roll it out again? Would this effort be worthwhile considering the limitations imposed by the foil?
No....... it's much more prudent, and safe, to pre set the rake for overall helm attitude and use the myriad of other controls to balance the headsail and mainsail while sailing.
geehaw
May 15, 2010
231
Well Morgan Might have it right. All I know is that the boat was so cranky with the 100 jib I thought I would never learn to sail.Until I put the 130 on. I had the greatest time that day 3' to 4' seas boat was screaming along. The heeling didn't bother me because I felt in control for a change. I even spent some down below to get out of the rain for a bit. I did have the main eased a bit but I had the jib in pretty tight as I recall.
Joe
Jun 1, 2004
8,323
Get this book if you want to become a good sailor: http://www.amazon.com/dp/0684854201/ref=rdr_ext_tmb
"The Annapolis Book of Seamanship" by John Rousmaniere.
1,096
CS 30 Toronto
You might have overlooked the jib Fairlead position. It might have been placed (or not adjustable) too far back for the 100% but suits the 130%. If the Fiarlead is too far back the sail will be too flat to generate lift.
I have a cockpit adjustable fairlead system from Garhaurer, the best investment I ever made to the boat.
385
Harpoon 5.2 Honolulu, HI
I used to have an O26 and it was also very cranky with the jib versus the genoa. Now I never tried to fly my entire 130 in 20 knot winds, but the boat always balanced and pointed much better with the bigger sail.
Geehaw the 25 and 26 are very similar - those boats also do really well under genoa alone if you are feeling lazy.
