Moldy life vests
Ricky
i have about 30 life vest that I store in the aft locker on my 44 Hunter. Some of them are getting a little smelly. Is there a way of soaking them to get rid of the moldy smell?. I was think of a clorine/water solution. Has anyone tried this or some other way of dealing with this problem?
Pure Ayre has been mentioned by Peggie to be a very good odor eliminator.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Soaking them in a vinegar/water solution might do the trick... and probably will be less damaging than using bleach
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
I had good luck using a very diluted bleach solution in a spray bottle, then misting the life vests. It needed two applications, but that did the trick. You can test this on a small area if you are unsure.
I did not want to soak the vests in a bleach solution. This method was easy and successful...and a lot less expensive than Pure Ayre.
KD3PC
1,069
boatless rainbow Callao, VA
they make an enzyme cleaner for dive gear that really works, and even worked on my kids sweaty lacrosse gear...check your local dive shop....
Jan 10, 2009
590
PDQ 32 Deale, MD
Throw them away. Do you really want 30 guests?
Sounds like a nightmare.
Just joking. Bleach and Spic-n-span has been my choice. Basically, deck cleaner from Home Depot, if you would like to buy it pre-mixed.
Oct 22, 2008
3,502
Probably not a great idea to mix bleach with other cleaners.
RichH
Feb 14, 2005
4,773
Any strong soap or strong detergent will **dissolve** mold/mildew. These soaps are 'caustic'. Just apply, cover and let soak; then, rinse out. Old fashioned 'lye soap' is still probably the best and was used exclusively for hundreds of years by our 'ancestors' especially for this purpose.
Aug 11, 2006
1,446
Hunter H260 Traverse City
I've never tried it on clothing but Slimy Grimy is great at eliminating algae and mildew on hulls and my deck at home. It's just amazing...
