Hi Caguy. What is the formula for the vinegar solution. I would like to try this before going to acetone or lacquer thinner. But I will try anything to get the stuff off. It ruins the excellent profile of my 27 year young Cat27.I recently used foaming bleach and a soft scrub sponge to clean mine and the deck. It's really convenient and does not run. It stays where you spray it until you wipe it clean. I would follow up and plan to on the C27 with a solution of vinegar as suggested by Zeehag. My decks are still mould free after 3 weeks but I will still treat with vinnegar after googling it.
Haven't tried it yet, but I would use it straight out of the bottle. I would use the bleach foam and socft scrub spnge first to remove it. That I know works and then the vinegar straight out of the bottle to keep the mold away.Hi Caguy. What is the formula for the vinegar solution. I would like to try this before going to acetone or lacquer thinner. But I will try anything to get the stuff off. It ruins the excellent profile of my 27 year young Cat27.
