Sherry: In Short, Don't Worry, Be Happy!
Assuming nothing is grossly wrong with either your marina or your boat's wiring, all a zinc on a fresh water boat does is prevent the the prop from hitting the rudder when the prop shaft pulls out of the coupling (a very unlikely event that I have actually observed).Although zincs are absolutely required in salt water, and STRONGLY recommended in brackish water to prevent galvanic corrosion, fresh water is a terrible conductor of electricity, and galvanic corrosion is therefore negligiable because it is very difficult to set up the required (corrosion) circuit, even without a zinc.On Lake Michigan (usually considered to be fresh water), there are a few older boats that have zincs, but I have never seen anyone actually change one.If you have electrolytic corrosion (due to stray currents), a zinc may protect the part of the boat that it is actually connected to for a short time (e.g. if you have stray electrons running around the boat and a zinc attached to your prop shaft, the prop shaft should be OK, but any metal through hulls may be eaten), but electrolytic corrosion is fast, and the zinc will go away if this occurs.In short Sherry, a zinc on your boat won't hurt, but of you don't have one, don't worry about it.SteveAlchemist C-320
