A little late to comment, but we use the track cleats for midship as well. We have one on each side because I found liked the fair lead for the line better when it was back, behind the jib car.
We use these chafe guards (http://shop.catalinaowners.com/prod.php?1645). A little more money but you can move them around easily. We have a set of two if these for dock lines. (we have lots of other chafe guard in our storm kit but still like these the best for convenience.)
The toe rail does have an aluminum plate imbedded in it if you want to attach a clear. You can see the post I did about adding cleats to the stern for the dingy. You could add cleats to the toe rail the same way. But if you use a spring line/breast line to dock I don't think I would rely on a cleat on the toe rail for it.
Another thing you could do is add a chock to the toe rail. I was going to do this but we almost never dock anymore so I decided not to go through the effort.
Good luck
Good luck
