mercury 3.3
Feb 23, 2015
1
Hi all ,I have a mercury 3.3 as an aux on my boat .
It went well, now it starts and once I put it in gear it starts to flutter and then stops.
you can restart and rev it up but still dies when put into gear.
I have had the carb off and cleaned, the fuel tap replaced and the hose as well , new plug, replaced the "o" on the carb and reset the float level as per the manual
What else can it be
Rick D
Jun 14, 2008
7,145
Being the local champ of field stripping a 3.3 carb in my dinghy (at least a half dozen times), I would not assume the jet is in fact clean. If it will run with the choke out 50% or so, it may warrant a new tear down and thorough cleaning including removing the jet. Of course, I know you disposed of the fuel, cleaned the tank, and cleared the mesh 'filter'. Good luck! After I used only clean fuel and always used Sta-Bil, no further problems.
