Came across this last week. I never feel good about mast up winter storage when the wind begins to blow. The added windage to the vessel on the hard can lead to potentially bad outcomes if precautions are not taken and the boat properly supported..
On land you don't have the keel opposing the vessel from the forces of wind only the boat stands that are meant for balancing the boat. A sailboat is a lot more stable in the water than on land and leaving the spar up can add unnecessary windage. That being said I have stored both ways but only in certain yards that have good wind protection. I can't say what caused this one to topple because it appeared they had done everything right.
This boat was roughly 28 feet:
1- Three stands per side + 1 bow
2- All stands had been chained
3- Boat was on solid cement parking lot
4- Boat was on proper wood keel blocking
I don't know what else could have been done differently in this case as everything appeared done by the book by a very knowledgeable yard in the mid coast region of Maine. The only noticeable difference between this boat and all the other mast up boats is that this one faced beam to the prevailing winter winds and the others faced bow or stern to..
The boat yard we store at has a disclaimer document that says if you choose to store mast up you and your insurance company are liable for any damages caused if your boat tips over.
Something to think about and as a good precaution check your stands on a regular basis especially if on a softer substrate.
P.S. Roger Long at one point you had done the calculations of the windage on your bare spars. Do you still have that data? My only reference point is that my boat will not heel in water without the spar, and it will heel, up to 15 degrees or more, depending on wind speed with just the spar & rigging and no sails..
