C
Chuck Petty
First of all, many thanks to the archives and photo forum on this site, especially to David Foster for his many H27 posts including the one regarding what makes up the “in-between” area from the compression post and the mast step (Search on “Check the mast step”).Second, this is being posted on the Cherubini forum. My apologies to all you folks that have picked this up by looking at recent activities and really aren’t interested in this rather long and fairly specific topic.Now to my problems:1. Wet spots on the port side at the top of the compression post.2. Wet spots and rot along the base of the starboard bulkhead.3. Buckling (bulging enough to make the door stick) of the starboard bulkhead My reading of the symptoms indicates that the most likely problem is deterioration of the cabin top between the top of the compression post and the mast step due to water damage, most likely where the mast wiring goes through the cabin top. Potentially this could extend to compression post and/or cabin sole issues. We all know how these projects can expand to exceed the contents of the wallet and the time available to complete them.The plan is to:1. Pray that the problem is limited to the mast step area.2. Have the mast un-stepped. ($300 – un-step/step/basic rig tune)3. Continue to pray that the problem is limited to the mast step area.4. Inspect and repair as necessary mast components.5. Did I say pray that the problem is limited to the mast step area.6. Inspect and repair the cabin top / mast step area.7. Keep praying that the problem is limited to the mast step area.8. Have the mast stepped and rig tuned.9. Go sailing.If I fail steps 1, 3, 5, or 7, put the boat on the market as a project boat. Just kidding, actually it will be to completely redo the woodwork in the head/vanity area including both bulkheads and repair the cabin sole as necessary. This is a project that I was hoping to defer until 2005 when the bottom will need painting. (The boat was half sunk in a prior life and there is cosmetic water damage) Note to Fred, I wish I could plant her in the back yard for this project but the homeowners association would not be impressed.This will be an “in the water” project. My marina has no facilities to put the boat on the hard unless it is on a trailer, which I do not have. Additionally, this is Texas and the sailing season is ongoing given enough water in the lake, the right wind, and the temp above 50 (admiral’s rule). Unfortunately, this will violate my rule of not doing anything to the boat that I cannot put back together and go sailing in a couple of hours.My request:1. Pictures of the mast step area (with mast un-stepped) to include: Intact Damaged Ripped apart Detail on how the wires are connected or run Areas that water may be trapped by design Sizes and shapes of the plywood and/or balsa used to build up this area (or per David’s suggestion the aluminum plate)2. Written descriptions of the above. 3. Suggestions for improvement.4. Information on what is between the sole liner and the hull in the head/vanity area. Mine is not accessible, although I have seen pictures of H27’s where there are floorboards here. 4. Moral supportI rate this as a 1.5 on the liters of scotch scale. I can be reached through the owner’s directory.Many ThanksChuck PettyS/V Following Sea
