mast sheave replacement
rkeene
Jan 24, 2015
6
ameican 14-6 14-6 dinky dock
Any instruction on removing mast head sheaves. Do you drill them out and rivet new ones in? Any help or links is much appreciated, The mast is down and easy to work on.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I thought the shafts were captive in the masthead die casting, and that it had to be removed to get the shafts out. If that is the case, the easy way is to drill out the rivets holding it in place and remove the unit from the mast. I could be wrong.
-na -NA Anywhere USA
If the boat is an American 14.6 daysailor, call American Sail in Charleston, SC and ask for Dave Stanton who can help you. The actual mast comes from Dwyer Aluminum and there are exploded views of the mast and hardware on line.
I was looking at the bio on which boat it was.
