It's keel stepped. There is a removable floorboard you can lift up to get access to disconnect the wire connectors. Then disconnect the shrouds, fold the boot up, and have a crane or similar lift it. You need to lift the whole thing out of the cabin before you can rotate it to horizontal so it's about 7 or 8 extra feet of lift. Also there's a set of shims at the cabin top you'll need to store until you re-step it.
