Meaning what?
There is a standard and precise procedure, using the mast raising tube (gin pole), the side-stabilizing bridle cables, the jib halyard, and the main sheet block and tackle connected to the eye bolt located in the anchor well. Did you not receive these accessories with your boat? I'm sure Hunter can provide an instruction sheet, as well as any missing equipment.Dale
