I know there's lots of info out there on this and I've looked at a lot of it..... in fact that's my problem. So I whipped up a pole with the bracket to bolt to the mast step drilled a couple holes in the step and it works but the step is too crowded even for the bolt heads I've got it working but want a better solution.
One would be and I'm sure I saw them in my reading is a bracket the bolts to the deck just forward of the step to pin the pole to.... and now look as I might I can't find any pictures showing a bracket like that. I was hoping to find out where I maybe able to purchase same. My other option would be to have a step made with a couple ears on the front to accept the bracket for the pole. I think my preference is the separate bracket even if i have to have it made.
Same subject different part for baby stays I have two stanchions just forward of the step so figure I could just add a ring or tab and eliminate having to mount something on deck.
thanks
thanks
