Mast Plate
Aug 26, 2019
64
Hunter 260 Eau Claire
Anyone seen a mast base like this? It is on my new to me 99 260. Also no hole in the mast to put the mast raising pole.
Can’t figure it out.
Feb 18, 2011
339
Hunter 260 Cave Run Lake, KY
My H240 has a similar mast step with no hole in the mast. Your mast raising pole should have a long clevis pin inserted through holes drilled near the bottom. The base of the pole attaches to the two vertical tabs on the front of the mast step, and the pin acts like a hinge as the mast comes up. Start with the pole a little aft of vertical and it will rotate down as the mast is raised.
Aug 26, 2019
64
A thousand thanks for your reply. The base of my pole does have a hole in it. I was initially skeptical about it because I thought it would be in the way when when the plate swings down. I’ll give it a try. Thankyou very much! I can relax now.
Likes: patbratton
-na -NA Anywhere USA
Not sure what happened but there is a thread on a 23.5 about 20 threads back on this subject. Take a look. Then get in touch with me
Dave Condon
