I consider buying a 2013 Catalina 14.2. The boat is in reasonable shape, but has some issue with the heel of the aluminum mast, that I never met before. It looks like the bottom several inches of the mast was covered with gray epoxy by the original owner, reportedly - see the picture attached (the original owner is not available for questioning, unfortunately). This area of the mast also looks like swelled a bit (increased diameter) - is this a normal configuration for Catalina small boat masts? The mast bottom is plugged and inside of the mast is unaccessible for view; the very top of the mast is open. The stainless steel mast seat / step hinge looks undamaged. Could this epoxy covering some aluminum deterioration, like cracking or corrosion (galvanic pitting)? Had anybody faced the deterioration of the mast heel on their boats? Could it be a serious structural issue or more aesthetic issue? Appreciate your responses - Boris.
