Heya all!
Based on research and conversations here and lurking other conversations this is where i'm at:
Total pre launch 2237
Triton $1400
antenna $70
windex https://www.amazon.com/Davis-Instru...id=1521642505&sr=8-1&keywords=sailboat+windex $30
rf terminator $30
rg213 $50
4 wire https://www.amazon.com/Ancor-154010...r=8-8&keywords=marine+trailer+wire&th=1&psc=1 $82
anchor light https://store.marinebeam.com/smart-led-tri-color-anchor-light-and-strobe-n3-tri-cmb/ $110
steamer https://store.marinebeam.com/led-masthead-steaming-light/ $90
deck lights https://www.amazon.com/Light-Northp...e=UTF8&qid=1521640992&sr=8-5&keywords=18w+led $15
grommets local hardware $10
deck drain hose local hardware $20
Primer https://www.jamestowndistributors.c...MIiqHNzMb92QIVSbnACh2vQg-KEAQYASABEgLxuPD_BwE $90
white paint interlux white poly $100
vinyl stripe local vinyl shop $80
coppercoat http://coppercoat.com/coppercoat-info/application/ (Probably wont do this, if i do its 460)
vc 17 https://www.jamestowndistributors.c...MI7L6w2cv92QIVA7bACh1wXAL1EAAYASAAEgKyuvD_BwE $60 (assuming i only need one kt, but i think i need more things to make it usable)
So - am i missing anything? totally off base with something else? The cost of mast rewiring and hull painting is greater than what i paid for the boat so i'm just being cautious.
Yes, i'm throwing in a the triton and want to get it installed while the mast is down, hence being a part of prelaunch. The boat has no ~working~ instrumentation otherwise.
THANKS!
Triton $1400
antenna $70
rf terminator $30
rg213 $50
THANKS!
