mast base mounting
JamesT
Jun 12, 2017
3
hunter 23 martinez, ga
Hi, I purchased the mast base/foot rebuild kit. The old base hardware was stuck so good, I had to drill the heads off, then grind the remainder flush with the deck. The new base has a different mounting pattern, which is good because I couldn't get the old hardware out. I'm in need of knowing the type of mounting hardware used for this install. I called usSpars and they referred me to sailboatOwners.com....neither could help. Also, if anyone knows how thick the deck is in that area....thanks
-na -NA Anywhere USA
Take a photo of the current mast step so I can see what we are looking at. Then we will go from there. All the wing keel 23's came with the Z spar mast and now U.S. Spars mast. Same mast but under different name. Long story but not wanting to discuss as it would bee too long.
Photo please. Also copy me via personal message forum email. Never put your contact info on this site for security reasons.
Crazy Dave
