my 29.5 did the same thing. it comes in the wiring conduit. when I had the mast out I added a taller section to the conduit inside the mast and then bent/arranged the wiring so it looked like a drain trap and the water coming down the wiring dripped to the side instead of continuing down the conduit' a little riggers tape at the top of the conduit and problem solved!
good luck
