Massive Coronary only Minutes from the Marina
342
Pearson P-31 Quantico
A blown or even weeping head gasket between two cylinders can cause water leakage in a cylinder.. .
Suggest that if you find compression anomalies
'amount of metal still remaining in the block'. . .
www.moyermarine.com sells rebuilt 'short blocks'.
Check out . . .. BEFORE you jump-the-$$$$gun and 'repower'
RichH
I think not wrt a blown or even weeping head gasket. We have no known water leakage in a cylinder.. .
I will compression test -- yes!
'amount of metal still remaining in the block'. . . understand
www.moyermarine.com sells rebuilt 'short blocks'. GOOD. I can work from there.
Check out . . .. BEFORE you jump-the-$$$$gun and 'repower' YES!
MANY THANKS BACK TO YOU! I need the help!
Robert
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
Another possibility is stuck valves due to the crap gas that we have now. Have seen the valves seize on a rebuilt Austin Healey with 10 hours on the engine. Car sat for a couple of years and the old gas caused shelac or something to seize the valves. This is OHV interference engine and bent the valves and push rods. Pretty shocking to see. We use lots of Stabil now on the vehicles that don't run much.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
After having rebuilt probably 500+ engines in my life I'll offer my 2-bits. A gas burning engine must have:
1. Compression
2. Spark at the plugs at the proper time.
3. Fuel delivered thru the carb.
Engines can suffer massive internal failures without noise. Broken camshafts and broken timing gears or chains all can cause loss of compression without noise. A head casket failure is very low on the list of possible causes.
Before all else you need to do a compression check on all cylinders. If there is no compression on more than 1 cylinder stop here and check distributor for rotation. If the rotor turns then use a flashlite and look thru a sparkplug hole and see if the piston goes up and down as you turn the motor over by hand. If you can't do that then use a soft but somewhat ridgid piece of wire to place in the sparkplug hole and with the distributor cap off slowly turn the engine over by hand and see if the wire goes up and down. You must hold the wire in your hand during the entire process so you might need a helper. If the wire binds up then STOP rotating the motor so you don't bind the wire in the engine.
If you find that the pistons are not moving you have had a fatal heart problem.
If you have rotation of the pistons and rotor but no compression then check valve lash adjustment.
If the valves do not go up and down as you turn the engine over to set valve lash then the camshaft is broken. Engine is toes pointing skyward....dead. If lash is OK, pistons go up and down and rotor goes around in proper time with the pistons and you still have no compression then the motor is worn out. Also considered a fatal flaw.
You know there is fuel getting in the motor so I'll not go there. I think you can figure out your problem with these tests.
Good luck, Ray
Apr 22, 2009
342
redacted . . .
After having rebuilt probably 500+ engines in my life . . .
do a compression check . . .
check distributor for rotation. . . .
see if the pistons go up and down ...
check valve lash adjustment . . .
Fuel . . .
Good luck, Ray
Ray,
Thank You!
We are scheduling the compression check
Distributor rotates.
Pistons, at least two and I will eyeball all, go up and down ...
check valve lash adjustment . . .? How and what is this?
Fuel, I am going to prime the fuel pump using the "v-shaped handle" to ensure I have no fuel problem. But I am very sure, right now, it is not a fuel pump issue.
I do not want to say anything like, "I spoke to Ken at Moyer Marine and he said . . ." but I think we know that Ken and the rest of the guys at Moyer Marine are more interested in doing what we need to do rather than what one might foolishly do. So, where I to talk to Ken and say, I think my engine is dead and I need a whole new engine, he would probably say something along the lines of, well, lets see what the problem is.
No vacuum means no compression and if that is in all four cylinders, you proabaly have a cranking excessively moisture issue that has stuck the valves open. Rather than a new engine, you probably need new valve something or others and new valve something else or other. So, you probably need to spend a couple of hundred buck vice buy a new engine.
SOOOOOO, I am thinking, stuck valves.
And above, there are some others who suggested the same and some possible remedies. We will see.
Thanks for the reply!
Many Thanks for the Reply, actually.
Robert
RichH
Feb 14, 2005
4,773
The best way to assay if the valves, usually exhaust valves, are stuck is to remove the intake manifold .... and open the 'cover plate' directly underneath.
A4 valves can easily be 'unstuck' by simply spraying on "PB blaster" to the valve stems ... both through the spark plug hole ... the spray angled to the valve stem and on to the stems exposed by the removal of the cover plate. Spray the stems and 'work' the valve up and down by using an "L" shaped device through the spark plug bore.
If you do have stuck exhaust valves ..... continue your 'search' to find the pin hole water leak in your exhaust system (exhaust manifold and/or water lift muffler, etc.) that is 'back filling' the engine with WATER when you shut down. The A4 exhaust manifolds are notorious for pin hole water leaks.
Nov 6, 2006
10,253
Good news that all the turning stuff is turning.. Get a headgasket and pull the head.. remove what I call the tappet gallery cover, the one Rich calls cover plate.. behind carb and intake manifold.. You can see the tops of the tappets .. There are adjustment screws /nuts on top.. don't mess with that yet.. Any valve that you see off its seat after you pull the head should get a squirt of oil on its stem so that the oil can drool down into the guides. Squirt the bottom of the guide inside the gallery so that some oil will wick up into the valve guide.. Take a block of softwood like pine and tap down the valves whose tappets you find loose .(take extreme care not to bend the valve). Roll the crank a couple of times and watch the valves.. re-oil the sticky ones tap down .. work em up down until they get free.. Continue to oil the stems top and bottom until the valves are completely free.. Clean out the tappet gallery and use engine oil to oil the tappet bores.. Make sure they are clean and free. .. Now check the valve clearance and set according to specification.. Spin it with the starter to make sure nothing is sticking before going back up with new head and gallery cover gaskets... Some folks might recommend Marvel Mystery oil in the fuel and in the crankcase until you've run it 4-5 more hours. Good Luck
342
Good news -- maybe it seems, and THANK YOU EVERYONE helping and suggesting stuff, including Ken and Don at Moyer Marine, and now too, RichH and Kloudie1, for the suggestions and maybe even the good karma.
Bad news -- if this is any -- the available mechanic (me) weights more or less 200 pounds and the work space might be ok for a sixth grader. Oh well, at least I won't be overqualified by edgumecation.
Seriously guys, thanks. And YES, I will post some pictures.
Robert
RichH
Feb 14, 2005
4,773
Stuck valves on an A4 usually free-up easily .... just keep applying a rust penetrant to the stems and forcibly 'push' the valves down as you hand rotate the crankshaft. Once fairly free and the stems are repolished they will stay that way ..... but then carefully inspect the entire exhaust system for *pin hole* leaks between the exhaust gas side and the 'water side'.
Pressure test the exhaust manifold for pin holes.
If you have a jacketed 'connector pipe' between the exhaust manifold and the 'steam riser', ditto pressure check, etc. Ditto if you have the Pearson COPPER jacketed 'steam riser'. If you DO have the Pearson copper 'steam riser pipe' .... take it to a 'red metals' fabricator and VERIFY that the 'witches hat' inside is 'still there'. If the witches hat is missing water can be back-injected into the exhaust system (when the exhaust flow is minimal as when idling etc.).
Rick D
Jun 14, 2008
7,206
Suggestion
You have gotten plenty of advise. I was part owner of a 1914 Fay Bowen which had a re-power with a Grey Marine which I believe was the same block as yours. It was raw water cooled in salt water. It was way too much power for the hull.
Anyhow, we constantly battled carb and valve issues. The carb problem was stale gas since it didn't get used enough. The valves were because the engine never got hot enough nor ran long enough to burn off the residue. As a result, eventually the valves would get stuck in the guides. We had to do the PB blaster treatment several times over a week and work them, clean out the valve galley and change the oil a couple of times before all was back in order. (Another problem is that this engine had no thermostat.)
Anyhow, it looks like you are getting closer to identifying the problem. I guess you have ruled out a bad crank or cam. I assume you checked the distributor drive too. Good luck!
Edit to add: also, once we found that a valve spring was cracked. It had enough tension to close the valve when the engine was turned over by hand, but not when it was running. That was a bugger to figure out. We later found another. We replaced all the springs.
Oct 2, 2006
1,517
Jboat J24 commack
One of the things i found in owning two A4s is they changed the valve springs at point X in time and the new one ones are MUCH stronger
You should be able to find out by counting the coils and asking Moyer
The valves are pretty costly so there worth getting ground IF they seem in otherwise good shape
Due to being kind of cool i have found under the intake valves the motor built HUGE amounts of carbon to the point i was supprised the motor could even draw in enough air to run
The valve keepers can fall INSIDE the motor so IT is a good idea to stuff rags in the oil return holes to keep out parts and DIRT :)
The modern head gasket is THIN and you are supposed to use TWO to or the compression will get kind of high
Rick D
Jun 14, 2008
7,206
Thanks to TomMays...
...for these hints. I forgot about it (or at least was trying to):
"The valve keepers can fall INSIDE the motor so IT is a good idea to stuff rags in the oil return holes to keep out parts and DIRT :)
RichH
Feb 14, 2005
4,773
VERY GOOD point .... at near the production series end of the Atomic 4, Universal 'unloaded' quite a few of the 'industrial version' (higher compression) A4s to Pearson. Don Moyer has an 'insert' that fits to the head and requires 4 head gaskets (two on each 'side' of the insert) to lower the compression ... you'll have to ask Don which serial number engines NEED this insert.
Nov 6, 2006
10,253
Looks like a possible blown gasket between nearest and second nearest valve pockets in the head?? Cylinders 3/4 maybe.. Time to get some Clover valve grinding compound and a twirler stick and fix the seats. Rick's advice is excellent about packing the holes so the keepers can't get away from ya. Compress spring, pull the keepers and remove the valves .. rolling the engine to get the tappets loose as ya pull the keepers. Clean each valve being careful not to bend the stem or scratch the seating face or the stem. The example in this video is an ohv engine, but the technique is the same.. http://www.affordablegokarts.com/valve-lapping.php
Sounds like a consult with Moyer is in order re head gaskets/spacers/valve springs, as Rich says..
Oh.. ya gonna want to check the head for flatness and correct if necessary.. Also check the head mating surface on the block, especially between the valve pockets. .. Good luck
Apr 22, 2009
342
Re: Massive Coronary only Minutes from the Marina -18 Jun Up
WOW! THANK YOU EVERYONE.
Claude -- valve lapping -- cool link. Will do.
RichH -- Moyer, yes, I spoke to both Ken and Don and am doing as they suggested. I do not have a "Pearson copper 'steam riser pipe.'"
RickD -- the HINTS -- here's another -- THANK YOU! (In itself, the thanks are a hint back to you to keep them coming BTW). And I know a yard that has a Grey Marine (little four, power four, something four) motor sitting in a barn. OH, probably do not want any grit falling into oil well. Really important when cleaning all the stuff.
Tommays -- Moyers - yes and already ordered NEW SPRINGS, yes!
Waiting on parts! THANK YOU!
Robert
Rick D
Jun 14, 2008
7,206
Spring Compressor
You'll need a spring compressor; at least we did. Smaller is better. Look for a little one.
Apr 22, 2009
342
Rick D -- GOOD NEWS - sort of. I bought the "Atomic Four Spring Compressor" from Moyer Marine. It wasn't too expensive (I do not remember the detail) but it was all for less than $200.
TWO head gaskets and one each of valve cover, thermostat, in/out manifold, exhaust, carburator gaskets.
One set of eight HD valve springs.
Moyer A4 valve spring tool.
Moyer Marine Shop Manual.
One set, Water lift muffler bearings.
Shipping.
Rick D
Jun 14, 2008
7,206
Well, that ought to do it! Good luck and let us know how it goes!
BTW, It's really easy to lose the valve spring retainers when pulling them; good luck. I'm sure your valve spring compressor will be much better than the auto parts store ##@&&(+_ one we had.
Apr 22, 2009
342
I have had timing gears or chains break . . ..
Ross! Thanks for the post. FORTUNATELY - everything turns and half the valves do go up and down. And the more I read and review on this, the A4 is known to have issues with "sticking valves." More fortunate, while I have never done a valve job before, I do have some mechanical and craft capabilities.
See the pictures, and see the last posted picture -- in Wednesday's mail -- PARTS, MANUAL, and TOOLS. I need to go to K-Mart and buy a gallon of carb cleaner, and a .32 caliber bore brush (I have 9MM and .308 cal). And to the Auto-part place for lapping compound.
This weekend, maybe I will have time, or maybe this will have to wait for next Wednesday.
BTW -- the floor beneath the parts is self installed (brother helped, or did I help him?) red oak, replacement for linoleum and carpet in kitchen and dining room.
