Dennis
With the fresh water seacock open the standard a/c that came with our '99 H340 shuts off. The code on the panel says HHH (I guess overheat) and then shuts off (probably good). Appears no water flow out the discharge thru hull. Pump is an obvious culprit. Anyone know of a convenient way to check this or other possible probles... thx
