Jane
My boat came with an electric head which worked great until just recently. For expediency, I just took off the electric pump and replaced it with the boat's original manual pump. This is my first experience with 'pumping'. I did replace the joker valve when I put the manual pump on. So my point is I know what the joker valve is; but is there also a gasket(flap)that works to keep the water from flowing back? I can pump for ten minutes and only a fraction of the water is removed (it all comes back onto the bowl when I depress the handle, nothing stops it from being pumped right back into athe base of the toliet). Doing a little research it seems it might be the base valve gasket Jabsco part number 29043-0000. I do have a gasket(no flap) in there but it was the one that was on the pump when I had the electric pump. Do I need a different gasket? As usual thanks for all the great help.Jane"Echo"1996 29.5
