C
Chuck Graser
COLUMBINE'S C-30 macerator is stuck. We know that it should be turned on periodically, but we pump-out unless we are in the ocean. We hope that someone has a simpler solution to freeing the impeller than pulling the pump. (It is almost impossible to get to two of the screws holding down our pump, and the screw heads have been damaged. At least we have cleared the line by pumping out with the thru-hull open.
