Mac 25 Winch
1
Macgregor 25 Saint Louis De Kent
Winch will not move up or down so I am going to replace it with a small 12v winch I have hanging around. Last fall I looked a bit and didn't see much of a way to get at the old winch. Does anyone know if there is a video online about the winch and its removal? Or any info really...
Thanks
Mar 20, 2012
3,983
not sure what winch you are referring to.... a photo is a great asset to to a post like this so we can see a bit of what you are seeing.....
if its the keel winch, it can be replaced for about 40 dollars. but if its all the way up, of course it wont move anymore and to crank it down, the clutch could be a bit rusted to the plates. you may have to put a bit of force to it in a counterclockwise direction to get it to move..... or maybe the crank handle could be rusted to the clutching threads on the shaft.... use some PB blaster on it for a few days and try it again..... or replace it and the cable.
if it is just the sheet winches on either side of the boat, they are very easily disassembled, cleaned and lubed..... and simple to reassemble.
if its the trailer winch you are referring to, it can be replaced for about 40 dollars with a new one.....
if you have any other winch on the boat it will be a Previous Owner add on and we need more information to be able to make any assesment...:)
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
Try searching trailer sailor here at SBO for 'keel winch' and also post a picture of what you are able to see. What year is your Mac? The PO has likely added structure that hides the access and you also will need to modify, to add power.
