M25 rigging unknowns
14
magregor 25 Green Cove Springs, FL
Trying to figure out purpose of hardware in two places:
1st pic- plate with threaded hole on both sides of mast outside shroud mount?
2nd pic- slider rail with eye mount on both side of cockpit close to cabin?
Appreciate all input..... stumped sailing expert at West Marine....
958
Hunter 260 Pepin, WI
alcyone,
You might want to move your post to the Magregor side. You ended up on the Hunter forums.
Jun 5, 2004
485
Hunter 44 Mystic, Ct
Mac 25
Used to own a 1985 MAC 25. I think the first picture is where the bracket mounts that holds the pop top up. There should be one on each side of the pop top. I don't recall what the slide rail was used for.
Jun 16, 2010
495
In search of my next boat Palm Harbor, FL
Not knowing Magregors at all, I would say the second pic is an attachment point for a snatch block for your jib sheets.
