I should add that the rule of thumb is that the cylinder capacity is 42% of the WC figure, which includes the 80% limit, as well as the density ratio of propane to water.
Makes it easy to do the math. Multiply WC by .42 for actual propane capacity in pounds.
And yes, those OPD's can be a pain. So can propane dealers who set their scales up without allowing for the weight of the hose - take your newly filled cylinder home, weigh it, and see how close it comes to the .42 x WC + TW figure. :Liar: If they're selling you 20 lb, you should be getting 20 lb. Those exchange services commonly sell you less than 20 lb, which is ok if they tell you how much you're getting, but I don't think many go out of their way to tell you you're getting 16 pounds (for instance).
Of course, with a lightweight aluminium or fiberglass cylinder, the OPD should close it off before the scale tips, but I guess that depends on how close your dealer is paying attention. You may actually get the full amount, if the OPD doesn't close too soon.
