P
Paul Meyer
I'm hoping to get a sense of how our two blade, prop size/pitch (12/8), and tranny ratio (2:1) compare with the few other C27s with low horsepower inboard engines. I'm am considering increasing the prop pitch of our Petter 6hp powered 1973 C27. The prop is 12 inches in diameter. The local prop specialist has examined it and confirmed that it is balanced and not bent and the pitch is 8, as marked (12 x 8). The engine moves the boat at about 5 to 5.2 knots at full throttle on smooth water. As waves and wind rise against us, speed eventually goes to zero, even at full throttle. Not surprising - its a small engine. But when this is happening, every now and then the engine abruptly over-revs, and we have to momentarily back off the throttle to let the engine recover rpm control. This only happens when the engine is being worked its hardest - it works fine otherwise. My questions: Has anyone else experienced this pattern of occasionally over-reving when motoring into wind and waves? Petter 6hp owners (and others with low horsepower inboards): What is the diameter and pitch of your prop, and transmission gear ratio? I'm considering having the pitch of the prop increased from 8 to 10. Anybody have an opinion as to whether that might help? I'm sure people will ask about current rpm at full throttle. I was going to install a Tiny-Tac late this past fall, but the boat had to be hauled before I could get it installed. So we can only guess, but I am considering taking the opportunity to add prop pitch while the boat is out of the water - just to see if it helps. Any knowledge, experience, and predictions would be appreciated. Paul Meyer, New Brunswick, Canada
