Lost jib halyard up the mast
Mar 21, 2016
1
Cal Cal 227 Deltaville Va.
Done it both ways. First time I stood on the dock at low tide with two 10 foot long 3/4 conduits with a piece of heavy duty wire as a hook. Took about 10 min. but it worked. second time I found a fellow sailor who was on the small size and up the mast he went bosun's chair.
Nov 8, 2010
11,386
Problem is there are few people I trust to hold the other end of the halyard
Ohh then you're sailing with the wrong people. Or you should train. On our boats I expect the crew to be able to do anything I can... that's the only way to have it if you expect to survive an emergency; in particular one that renders you unable to help.
Oct 19, 2010
14
Pearson Electra/Ensign Lake Charles, LA.
Thanks for the suggestions!
I tried a modified version of the fishing approach, using the main halyard (as I don't have a spin halyard rigged). The disadvantage is that the main halyard runs up the aft edge of the mast whereas the shackle is stuck on the forward edge right at the peak. I taped a boathook to the main halyard with a band of tape just above the midpoint of the boathook and another band of tape near the end, this allowed me to hoist the boathook vertically, hook end up and able to extend above the masthead. I attached a spare sheet to the end of the main halyard for a tail/downhaul/control line. Then I led the halyard out around the shrouds -
I wasn't able to catch it with this rig however. So next I borrowed a large magnet from the marina (they use it to fish up lost keys and such around the docks) and taped it to the hook. I got the magnet right up against the shackle but it wouldn't stick strong enough to pull it down.
One more thing I'm going to try before I give up and obtain or make a bosun's chair to go up myself (or better yet, find a lightweight person to go up while I crank the winch) - that is to attach a telescoping fishing pole to the boathook. I figure I'll have better control with the boathook only 1/2 way up and can grab the shackle with a fishhook.
Clip your main halyard to the dock and start cranking the boat over until you can reach the top of the mast. :liar: :laugh:
Oct 19, 2010
14
Well said. I laid my boat over in the slip using the main halyard run over to the neighbor's dock. Just have to make sure your dock lines are correctly spaced and you have clearance between your rig and the dock when heeled.
May 16, 2015
114
C&C 37 28127 Port Madison, Washington
I'm filing some of these suggestions for when I have a tall enough mast to have the problem. Obviously, there are lots of ways not to do this. Here's one: In college, I was foredeck on a Santana 20 racing on Yaquina Bay, Oregon. Someone lost the end of the spinnaker halyard up the mast at the weather mark. I told Skip (half-ironically) to keep the boat steady while I began shinnying up the mast, which commenced swaying exponentially with every pound I placed aloft. Managing to wrap a toe around a spreader bracket, I pushed my weight upward, gaining the elevation needed to reach, with one outstretched hand, the leeward dangling shackle. It was a fine day and the view was spectacular. I called down to the bug-eyes in the cockpit to uncleat the halyard, placed the shackle in my teeth, and polished the mast well upon my descent. We finished last, assuring everyone another crazy-assed Duck boat story to toss around the clubhouse in Eugene.
Jun 8, 2015
26
Oday 222 Tahoe
I used two sections of pic pipe 1" into 3/4 with fork taped to the end. Kink of hard to use ase it flexed so much. Did get lucky however and captured it.
Dec 30, 2013
56
ODAY 322 Portsmouth
I might be easier than you think. Walk the main halyard forward and tie a big lazy overhand knot in it such that the tightening side goes aloft. Tie a bit of length small line to the bitter end such that when pulled it will close the loop forming a snare.
Now hoist the snare aloft using the small line to guide it up over the lost halyard. Yu may need to rock the boat to get at it more easily. When the halyard is in the loop close the snare by pulling down in the small line, and haul it in..
Likes: uncledom
Dec 30, 2013
56
ODAY 322 Portsmouth
Here you can see the "Halyard Snare" in action. The While/Blue/Red line represents the loose line being finagled into the snare. Once snared simply hold the uphaul end of the available halyard and pull the downhaul (small line) to close the snare.
56
Hunter 376 San Rafael
I did this before when the stitching gave way on the head of the jib and the shackle went aloft.
Use your main halyard shackle as a hook. Open up the main shackle so the pin sticks out (if it will come completely out, then duct tape a small stick to it so that it sticks out to the side). IMPORTANT!! tie a downhaul line to the main halyard. Raise the main halyard, and use the downhaul line to guide the main shackle to the jib shackle so that the main shackle pin (or stick) hooks it. Then pull both back down to the deck.
Jul 26, 2015
42
Watkins 29 Ft. Lauderdale
If your going to have someone haul you up on the main halyard... be smart...get 4 friends to do it.. and use two halyards.. years ago on a Dufour 34, we used the main halyard, and the spin halyard each to it own winch.. one trusted person to tail and one to crank on each winch...
Jul 24, 2012
53
Hunter H31 Saint John NB CA
Any highway bridges around you could cosy up to? Might be easier dealing from the top down instead of bottom up.
Dec 27, 2011
279
Oday 272 Pensacola
I did same thing with roller furler. Never had one, so didn't know what to look for when raising the mast. Halyard (when jib installed), is at deck level. If jib is dropped, end of halyard does to masthead.
Tried several types of 'hooks' (steel wire brush taped to spin halyard, PVC pipe sections joined to get to masthead (gets real 'bendy' by the time 3rd section is sent aloft. And just pushing sections together is apt to leave first section hanging from masthead.)
I wound up buying a Mast Mate, and at 68 find it to be a good investment. Didn't have anyone with a boson chair or experience with one. Decided I'd rather trust myself than someone else. And I could do it anytime I want...
Aug 27, 2015
58
Cal 2-46 Whitianga. New Zealand
The "mast mate" is interesting. I presume you must remove the main sail to get access to the track. Or have a second track. Certainly avoids the need for a second person. Of course you would need a decent harness or bosun chair as back up security.
For a quick and simple do it yourself emergency bosun chair try a "bowline on a bight". Might be a bit uncomfortable but OK for a quick up and down.
Aug 3, 2014
65
Beneteau 343 San Francisco Bay
Not a solution, but for those of you familiar with building, there are "stud clamps" that you can use to get up to plate level and I've often thought that with a harness backup, "mast clamps" would be a great way of getting up a mast. Also, has anybody ever used something similar to climbers' etriers, wherein you would have one for each foot and one for a chest harness, to ascend a mast? Sail on!
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Try to find or fabricate a small grappling hook with points at 90 degree intervals pointing downward.Hook it to a tag line and raise it with the main halyard. Since you only have about 30 feet of mast to concern yourself with, it should work.
If that doesn't work find someone with a TopClimber you can use. That makes it pretty easy to climb up the the tightly secured main halyard, grab the jib halyard and pull it down.
Feb 9, 2009
19
2 26 Lake Tahoe
While at the Marina, ask your two grandsons to start at the clubhouse and over at Restaurant row asking for two Sky hooks..... Also have them check the nearest Ship Chandlery. Then go to the Sea Scout Base.... Then.....
Alan
4,174
Hunter 35.5 LI, NY
Capta has the right idea. It's really very simple, climb the mast and drag it back down.
I'm up the mast (55') a couple times a year. I use a climbing harness and a pair of ascenders.
Up and back in 5 minutes. It's really quite easy and you don't have to been a gymnast to do it. I'm nearly 70.
I'm going up in a couple weeks (after launch) to replace wind vane cups.
Oct 10, 2013
35
Beneteau 343 San Diego
If your shackle stuck to the magnet, then the first thing you'd want to do is get a new shackle. Stainless steel is non-magnetic.
danm1
Oct 5, 2013
233
Hunter 356 Mamaroneck, NY
Another vote for heeling the boat with the main halyard. Worked for me. A friend pulled it over at low tide while I climbed a ladder on the bulkhead. Not my proudest moment, but I got the job done.
