looking for a good gas engine mechanic in Annapolis/Baltimor
stx203
Oct 15, 2009
58
Oday 25 Tall Rig Fin Keel Chesapeake - Middle River, Md
Hope everyone is out enjoying the 4th.....my 1977 Oday 25 with VIRE 7 inboard is sitting in the slip since the engine won't start. This is the original Finnish single cylinder 2 stroke gas engine that has run like a champ.....except for this year. I'm looking for a recommendation for a mechanic that is very familiar with work on a small gas marine engine in the Annapolis/Baltimore MD area. I found one guy but he was too big to get in the cockpit locker to service the engine. I've done all the usual...fresh gas, new plug. new fuel/water filter, appears gas is getting through as plug is wet with gas when I remove it after cranking for 10 seconds...just seems like it isn't firing....hope someone here might have a good reference. Thanks.
Re: looking for a good gas engine mechanic in Annapolis/Balt
Have you tried new plug wires? Is there a distributor on this engine?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
would only be one wire on a single cylinder engine....can you check the point setting or is it capacity discharged
stx203
Oct 15, 2009
58
There are points and magneto coil behind the flywheel...trouble is on the ODay 25 the engins is mounted within 2 inches of fiberglass bulkhead....will need to cut access panel in glass to get access to flywheel or pull the engine...neither being fun tasks.
