looking for a 4lb propane tank
25
Catalina 28 Victoria
Hi, does anyone know where in the Victoria, BC area that I can get a new 4lb tank to fit in a "Seaward" locker in my Catalina 28. Thanks
Feb 12, 2004
85
- - Stingray Point, Va
Seaward
Seaward is still in business, might want to try them. Other alternatives are camping & RV parts and accessories stores. You can try your local natural gas/propane dealer, they can generally order tanks, but aren't usually the cheapest.
David
Tanks
Just purchased two from West Marine. They had to special order them.
Aug 26, 2007
284
Hunter 41DS Ventura, California
Propane
I just replaced mine through Seaward. My boat is a 1992 and the new tank doesn't fit in the old box ( a shade taller ) but Seaward sells a new molded top which allows you to use the old box- no mods necessary. Not cheap- I think the tank was around $100 and the lid was $66. If you have the old tank and need a new valve, it can be retrofitted for $25- 40.
Catalina 320 Dana Point
REI used to sell one that was reported to fit
I've posted website for the 4.25 they stock currently, says it's 11 inches high, I can't remember exactly what those lockers measure.
C
Chuck Graser
New valve at Propane dealer
If you just need a valve that conforms to new regulations, a propane dealer can install one, and it is much less expensive than a new tank....... Chuck
Tony
propane tank upgrade
Where did you get your propane tank upgraded Tony
