Longstory
You have sturred up some some expensive thoughts.............
"New VHF below, with GPS / DSC and RAM MIC up topside. (still deciding best place at the wheel or on the side compartment - for ease of wire run)"
Well I've only used my below fixed VHF radio only once since I've had the Catalina 310........that was to listen to a
weather report when my HZ850 battery went dead.
My new proposal is install a Explorer GX 1700 outside under the instrument pod on the pedistal........seems I have to run a new big cable
in any case......and you know I'm not sure why the fix VHF radio is placed below anyway.
Now looking at using Ancor RG213u cable run.
:hijacked:
On the mast top, does the existing cable run down an existing conduit ? and is there enough room to install a new
approx 7/16" dia new cable in the conduit?.
On the pedistal, is there room to run a new cable up thru the stantion?
Some things I have to ponder.
paulj :troll:
:hijacked:
paulj :troll:
