Long Time Boater, Short Time Sailor, Cat 27 question
Mar 22, 2017
1
Catalina Catalina 27 Channel Islands
Hello Everyone,
Been boating for 56 years. I previously owned a Clipper Marine for a few years and just bought a 73 Catalina 27.
I'll get a picture later if this doesn't work.
On the stern, port side, is a metal plate that folds down and that hooks to a pump that's in the outboard compartment forward and left of the outboard.
There appears to be a handle that inserts into the socket (square) that you can use to rotate it which operates the pump.
What in the heck is that?????
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Yup, we had a 74 with outboard well as our first boat. That is the bilge pump, ours just pumped out into the OB well if I recall. We had an automatic electric bilge pump also that would exit a thru hull on the port side.
Nice boat, built before they mandated a different formula for the layup, no blisters. Also a pretty thick hull. She was a great sailing boat in light winds.
