Ric, do you have a source for the Starboard? I have some that needs replacing. Thanks, Walt To:
AlbinVega@yahoogroups.comFrom:
AlbinVega@yahoogroups.comDate: Fri, 8 Aug 2014 19:54:29 -0700Subject: Re: [AlbinVega] Re: Locker Lids
If you want varnished teak, the best way to approach it is
to buy one of the many drying agents on the market for teak and get as much oil
off the surface. Sand it and then put
two coats of penetrating epoxy on the bare wood. The penetrating epoxy seals the wood very
well. You need to wait for at least 5
days so the epoxy is fully cured, then you can start putting your coats of
varnish on. I used this process on a lot
of the mahogany I varnished, except I didn’t have the problem of removing the
excess oil. When you seal it this way,
you don’t have to thin your first couple of coats of varnish.
I made my new cockpit locker seats by epoxying 6mm and 4mm
marine plywood together. I find that a
single commercial sheet of marine plywood has a tendency to warp. By epoxying the two pieces together on a flat
surface, with heavy weights on top, I end up with a more stable product. To make the lids stronger, I epoxied and
screwed lengths of aluminum angle across the center, long ways, of each lid. I drill holes in the raised side of the angle
every couple of inches, which gives me the ability to put carabineers through
the holes and hang line from so I don’t have to go digging in the locker
looking for the line I want.
Here is where I probably part ways with most. Even though I used African mahogany finished
marine plywood, I painted the cockpit lids.
They will get a coat of non-skid also.
I have no exposed wood on the outside of my boat. All the beautiful varnishing is on the inside
where it will last for years and years with little work to keep it looking
great. All the wood on the outside, like
the fiberglass, is painted with two coats of epoxy primer and a minimum of two
coats of two part LP paint. I should not
have to worry about the outside wood for years either.
I used 1/2 inch Starboard to make my companion way slats from,
instead of painted plywood, because it is so stable. The only problem is that it is much heavier
than plywood, so you have to be careful how much and where you use it. The slats came out great and the Starboard
was very easy to work with.Rics/v Blue Max#2692www.ric-maxfield.net
