Link 1000
Tim R.
May 27, 2004
3,626
Do you really need all of that info. I don't and I cruise for months at a time. Keep it simple.
I did not on my previous boat but now I have 12v refrigeration and I think it is necessary to see a fairly accurate capacity.
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
Based on the responses here, and based on my experience with this unit, this is what I think it happening:
When I'm out sailing, including overnight, the monitor works as it should.
Same when I have the shore power turned off while the boat sits in the slip.
If the battery becomes completely charged up, and I leave the shore power turned on, then for some reason the monitor does not register the fact that a charge is continually flowing into the battery (actually, batteries); it only registers the parasitic draw coming out.
This is not such a great problem, as long as I know it's happening, and as long as there is not a problem with the shore power. Anyway, in general unless the batteries are down, I don't leave the shore power (i.e. the AC main switch) turned on for days on end when I'm away from the boat.
Feb 6, 1998
11,701
Geez, $300 for a digital voltmeter.
Actually they are not just digital volt meters and the Victron 601 can be bought for under $200.00. Volt meters, as others have pointed out, really tell you little about state of charge unless you have allowed the batteries to come to a full resting voltage with no input or out put for many hours. This is difficult on a cruisng sailboat, to completely isolate the batteries from all sources in or out, and thus any voltage reading may be off by a considerable amount.
Battery monitors keep track of the amp hours (Ah) going into and out of the battery bank, can display amps in/out (A), net amps to the bank, Ah's remaining, % state of charge, charge capacity remaining, volts and more.. Some can even be connected to a computer to graph and chart non-constant loads like refrigeration to give you an average daily consumption. They also tend to give the owners a great education of what is really happening in terms of charging and discharging..
Batteries are very, very expensive, especially AGM's & gel cells, and it is well known that cycling your batteries too deeply can severely shorten their cycle life. Even in controlled experiments on my bench I have not yet been able to nail down battery SOC with a volt meter closer than within 10% without a full resting period of 12 hours or more. Battery monitors, even at $200.00, can actually save you money in the long run.
You are 100% right that no one "needs" one but then again no one "needs" a boat either..;)
